Old 03-06-2010, 10:26 PM   #1
Installing laminate flooring over wood floor.
I recently pulled up my carpet to install floating laminate floor and once i pulled the carpet i found wood floor. It is the kind that has 4 small peices going the same way then the next set is switched. It is similiar to a parquet style floor.
Do i need to remove the wood down to the concrete before i install the laminate floor. Thanks
onenonlydano is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Laying down laminate flooring on a concrete floor Joey_1984 Flooring 10 10-04-2009 09:42 PM
Installing Swiftlock Plus Floating Laminate wood floor? bixa525 Flooring 3 07-13-2009 08:20 PM
laminate vs. wood flooring raghib Flooring 16 01-14-2009 06:04 PM
What is the best brand of laminate wood flooring powerline21 Flooring 17 03-24-2008 04:23 PM
