Installing Laminate Flooring In Out-Of-Square House - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 07:30 AM   #1
sweaty
Rewards Points: 276
Installing Laminate Flooring in Out-Of-Square House
I have a house, built in 1977, that we were thinking of putting in laminate flooring all over the main level, which has a living room, small dining room, kitchen, rec room, foyer, and half-bath, totaling 700 square feet (the rooms are small). We like the look, cost, and low maintenance.
I am concerned about it's being out of square. When installing, I'm afraid that, by the time I get to the other side of the house, boards will be at a visible angle to the wall. How much of a concern is this usually?
sweaty is offline   Reply With Quote
Old 05-25-2011, 04:13 PM   #2
DIY Damo
Not a big deal!
I have done hundreds of laminate floors and have never had an issue. Trim and quarter round usually fix that issue. You can try to find a laminate floor that has low profile seams. Always measure the rooms to see how far off square your are. Also, keep a 1/4 inch gap from the walls. Transition pieces at the doorways can solve this problem. You can also run the hallway a different direction. Good Luck!
diydamo77 is offline   Reply With Quote
Installing laminate flooring ? ants1929 Flooring 10 02-24-2011 11:46 PM
Question about laminate flooring jwemt81 Flooring 8 05-11-2009 01:09 PM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
Installing laminate flooring in basement, staples in floor Catalina76 Flooring 5 09-14-2008 01:56 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
