Old 07-20-2011, 04:51 AM   #1
sweaty
Installing Laminate Flooring in Areas That Will Get Wet
We're going to put in laminate flooring in the foyer, dining room and kitchen. We know these areas will get wet becaude we have little kids and eventually the house will become a rental. Tenants are not that careful.
Should there be a glue or wax between the planks when installing? I'm sure water or drinks will end up sitting on the floor. I want to avoid damage to the floor.
sweaty is offline   Reply With Quote
Old 07-20-2011, 06:34 AM   #2
Super Moderator
I think you should reconsider your choice of floor covering. Laminate is damaged quickly by water and is very difficult to repair.
oh'mike is online now   Reply With Quote
Old 07-29-2011, 11:35 PM   #3
I completely agree with Omike, rethink that decision. Laminate is not the right product for those specifications. And you shouldn't use glue or adhesive on laminate. Not a good idea. you will just ruin the floor, maybe even the subfloor...that gets expensive and time consuming.
ttr13r is offline   Reply With Quote
Old 07-29-2011, 11:36 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Why not a wood-look vinyl?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (07-30-2011)
Installing laminate flooring ? ants1929 Flooring 10 02-24-2011 11:46 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
