Installing Laminate Flooring ? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 08:45 AM   #1
Installing laminate flooring ?
I will be installing a new 8mm laminate floor by dream home nirvana with the attached 3mm underlayment my question is do i need to use any other kind of barrier the floor will go over a 90 year old tongue and groove pine subfloor the room is on the 2nd floor . thanks
ants1929 is offline   Reply With Quote
Old 02-24-2011, 08:49 AM   #2
Coatings Nerd
Same stuff I used in my last house...we really like it. We didnt use anything underneath over the sub floor, just make sure that its level, and any squeaks, screw them down now.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-24-2011, 09:09 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Don't worry about level, make sure it's flat. Flat and level are too entirely different things.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-24-2011, 09:18 AM   #4
Coatings Nerd
Same difference....tomato, tomatoe, color, colour.
Old 02-24-2011, 09:41 AM   #5
Rewards Points: 200
There is a Difference . You will find out what is is if it is not flat .
Floor Doc is offline   Reply With Quote
Old 02-24-2011, 10:15 AM   #6
Rewards Points: 12
A floor can be completely flat and way off level. And with laminate, flat is what's important.
Old 02-24-2011, 10:18 AM   #7
Retired
Edgar214's Avatar
Floor Doc, You are telling it just like it is. My house used to suffer from both. At least now it's flat.
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 02-24-2011, 03:05 PM   #8
i have a tongue and groove pine subfloor the boards are 3 " or just under 3" what would be the best way to level or flatten this sub floor thanks
Old 02-24-2011, 04:11 PM   #9
Rewards Points: 200
countersink any nails , and sand them with a drum sander .
How bad are they out of flat ?
Old 02-24-2011, 07:30 PM   #10
not to bad can i use a brad nailer i would use an 18 gauge nailer with 2" brads
Old 02-24-2011, 11:46 PM   #11
Rewards Points: 200
Sorry , I meant countersink any nails that might be in the face of the sub floor .
Pick up a 6' level for $30.00 at HF . you can check the flatness with that and full any low spots with tar paper .
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
installing laminate flooring garwoode Flooring 12 10-29-2008 10:21 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
