Installing Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 08:03 PM   #1
installing laminate flooring
I am going to be installing some Pergo accolade flooring, which has the underlayment attached. I was told I could install this directly over the existing carpet, which is thin in nature and in good shape. I'm skeptical of this advice...what do you think??
garwoode is offline   Reply With Quote
Old 10-24-2008, 07:58 AM   #2
RippySkippy's Avatar
Listen to the little voice...don't do it! clear the floor to the sub-floor and then install.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-24-2008, 09:54 AM   #3
Thanks..
Even though it would be sooo much easier...and even though I would have loved it if you'd said "sure, it'll be fine"....I just about knew that it wouldn't work as well. "If it sounds too good to be true...."
Old 10-24-2008, 10:52 AM   #4
Floorwizard's Avatar
It can be done. Make no mistake about it....BUT
It must be low pile commercial level loop carpet that is glued to the substrate.
Only in this situation is it acceptable and warrantied.
Floorwizard is offline   Reply With Quote
Old 10-24-2008, 03:03 PM   #5
Get out of the box!
Rewards Points: 260
It can be done as Florcraft suggest but it is highly prone to failure and unadvisable.
The movement will occur when the floor is stepped on, it will work the tongue and groove back and forth, this in turn will lead to premature failure of the locking mechanisim.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 10-26-2008, 10:26 PM   #6
hi iam going to install about 300 ft of flooring in kitchen and dining room in a manufactured home. Has anyone use Alloc flooring before? my am thing Alloc or Prego any advice?
jwag is offline   Reply With Quote
Old 10-27-2008, 11:06 AM   #7
Both manufacturers make good,better, and best qualities.
Any specifics?
Old 10-27-2008, 11:10 AM   #8
Remove the carpet
FYI: Laminate flooring dulls good blades quickly; most cuts will be under moulding thus rough cuts will be hidden
aggreX is offline   Reply With Quote
Old 10-28-2008, 07:28 PM   #9
Pergo floors??
I've been reading bad reviews about Pergo laminates--they're dull, hard to maintain, etc. Has anyone else heard this?? I thought Pergo was supposed to be the king of laminates?
rachel812 is offline   Reply With Quote
Old 10-28-2008, 10:54 PM   #10
hi rachel i am so confused the more i read the more i don't know what i want to do. when i go to my lowes store they don't have much beside prego and a few samples of alloc and swift somthing or other. don't know what i will do..
Old 10-29-2008, 08:13 AM   #11
I've seen Pergo and a couple of other off brands installed in kitchen, hall ways and living rooms where the families had a couple of large rowdy dogs. The laminate stuff held up way better than I thought. I did my kitchen, dining and hallway with a pretty cheap brand...and was really satisfied.
One thing many folks assume is that tough equals no maintenance....which isn't the case. You still have to be diligent with sweeping, protect the floor from chair/table legs and yes the stuff will scratch. Comparing laminate to linoleum, laminate wins hands down in my limited experience. In our new house we put hardwood in the same area (kitchen, dining, living, BF), so far so good. I don't have "the" answer...but it sounds like you're doing your research, and I'm sure you'll make the best decision based on your findings.
LMASD
Old 10-29-2008, 09:09 AM   #12
As mentioned above, just keep doing your reasearch. Every use/installation has different requirements.
In a kitchen, where the traffic from the back door brings in grit from outside, even with throw rugs, the floor will get scratched. Animals are another consideration and can cause other problems.
You need to follow best practices and buy a product that will meet your specific needs. What works for one person will not necessarily work for another.
I'd never install over carpet even though some say it's ok. Trapping all that smell/dirt under a new floor just bothers me for some reason even if it didn't move at all.
I've used both Alloc and Pergo with equal success. Again, as mentioned above, there are several variations of quality for every brand. There's a reason the price varies, look at the warranty for one example.
Shamus
Shamus is offline   Reply With Quote
Old 10-29-2008, 09:21 AM   #13
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I've put laminate over commercial low pile level loop once. It was glued down on top of Asbestos tile so I wasn't risking a rip up. Armstrong told me it should be fine to do this. 5 years later and it looks great with no issues. All I could say is make sure you use a good grade of laminate that is at least 8mm thick. The thinner the product the more chance you have of movement cracking the tongue. I'd be a little hesitant to put a product over carpet if it has it's own pad on the back though. That's twice as much room for movement that could cause cracking.
poppameth is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
installing underlayment for laminate flooring homeimprovement Flooring 2 10-01-2008 10:46 AM
Installing laminate flooring in basement, staples in floor Catalina76 Flooring 5 09-14-2008 12:56 PM
Need help installing laminate flooring jdubya Flooring 2 08-29-2008 07:18 AM
