Installing Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 08:34 PM   #1
Can we install laminate flooring without removing the baseboards? If so, how do we ensure that the expansion gap is accounted for without using spacers?
jcks is offline   Reply With Quote
Old 06-24-2012, 08:41 PM   #2
Rewards Points: 236
sure. but it wouldn't be installed correctly. why do you not want to remove the base board ?
Fix'n it is offline   Reply With Quote
Old 06-24-2012, 08:43 PM   #3
Rewards Points: 13,994
I never remove the baseboards, only the 1/4 round.
You have to use some form of space, with out one there's nothing solid to tap the pieces together againt.
I like to use strips of plywood not those cheap plastic small ones.
Old 06-24-2012, 08:50 PM   #4
We were trying to save time by leaving the baseboards on, to prevent damaging them or the walls we just painted.
If you don't remove the baseboards and use the pieces of wood, how do you remove them to allow for the floor to expand?
Old 06-24-2012, 08:59 PM   #5
If you don't remove the baseboards and use the pieces of wood for the expansion, how do you remove them to allow for the expansion?
Old 06-24-2012, 09:02 PM   #6
The plywood is only used as a temperary spacer, once it's done you remove them.
There just sitting againt the baseboard not attached to it.
JetSwet (06-24-2012)
Old 06-24-2012, 09:14 PM   #7
what width of wood pieces do you use to ensure the 1/4 round will cover the expansion gap?
Old 06-24-2012, 09:18 PM   #8
What's it say to leave for a gap on the box of flooring, whatever it says that's what you use.
Old 06-24-2012, 09:19 PM   #9
Rewards Points: 236
my bad. i don't use 1/4 round. i remove the BB and run the planks up close to the wall. reinstalling the BB covers the gap.
Old 06-24-2012, 09:27 PM   #10
If it's a sheetrock wall there most often 1/2" up off the floor, how would you be able to leave a gap if eveytime you tap the butt joints together the flooring slids tight to the bottom plate.
Leaving the baseboards on will save hours of work removing, reinstalling and all the needed tough ups.
Old 06-24-2012, 09:33 PM   #11
Our baseboards are going to be about an 1/8 inch higher than the laminate flooring we bought...doesn't the area between the baseboard and drywall count towards the expansion gap? So for instance the laminate we purchased says to allow 1/4 inch expansion gap...if the area under the molding is 1/4 inch deep, do we use a really thin piece to just butt the floor up against?
we are replacing a carpet and pad with 10mm laminate w/ built in underlayment.
Old 06-24-2012, 09:44 PM   #12
Check out page 378. removing the trim and base is optional.
To each there own, it works for me to leave it in place.
http://www.armstrong.com/pdbupimages/2127188114.pdf
jcks (06-24-2012)
Old 06-24-2012, 09:59 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
If you have small base molding and installing 10mm laminate which is thicker then say 7mm then your 1/4" or 1/2" quarter round might not make it look right. Might need to take the molding off but it is all on preference and the 1/4" gap is key no mater which way you go or how you make the gap stay.
JetSwet is offline   Reply With Quote
Installing laminate flooring ? ants1929 Flooring 10 02-24-2011 10:46 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 07:08 AM
installing laminate flooring garwoode Flooring 12 10-29-2008 09:21 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
