Installing Laminate Down A Hallway ? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 11:59 AM   #1
Installing laminate down a hallway ?
I have a livingroom with an attached hallway that Has a bedroom to the north, a room to the east, and two rooms on the south side that I want to lay pergo snap together in. The livingroom has the main doorway entrance to it. Picture a square in your mind with the front door entrance at the upper right, the hall in the bottom right running horizontal. Bottom left would be the kithen where ceramic is going.
Question 1: Do I start on the main entrance wall or in the hallway?
Question 2: If I start in the living room, do I stop at the corner of the hallway and if that piece overlaps the corner, do I rip pieces that turn in the hallway so they match up with the overlap I have in the livingroom so they become a straight line to continue.
6brnr is offline   Reply With Quote
Old 05-18-2010, 02:24 PM   #2
Handyman
Rewards Points: 512
I might be best if you could draw a diagram but I would say you can start wherever you like. The thing to consider is the orientation of the boards. If you have a rectangular L/R then, typically you would run the boards lengthways for the widest length. If your hall is parallel to the L/R you can continue but if it is perpendicular you may want to consider a threshold. Geez! Even I had to read that twice!
Ripping boards is almost always necessary so don't worry about that, so long as you leave some clearance at the wall for floating (which you can cover with 1/4 round)
Again, a diagram would be helpful.
Dave
canadaclub is offline   Reply With Quote
Old 05-18-2010, 02:33 PM   #3
Yeah, sorry about the confusion! Lol I'm on my phone so I'll try and get a diagram this eve
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-17-2007 11:18 PM
