Installing Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 08:21 PM   #1
Installing Laminate
We installed laminate floors throughout the entire first floor of the house. This includes kitchen, bathroom, living room and dining room. Now, we are removing a wall and an lower adjacent cabinet to install a kitchen peninsula. The big question is, now that I will have exposed concrete where the wall and kitchen cabinet were, can I fill in laminate in this area without removing all of the laminate from where the wall came out all the way to the closest exterior wall of the room. PLEASE TELL ME THERE IS A WAY TO PUT IN THE EXPOSED AREA WITHOUT HAVING TO REMOVE HALF OF THE FLOOR ON THE FIRST FLOOR. HELP!
Fatboymikey.brown is offline   Reply With Quote
Old 01-14-2009, 08:28 PM   #2
I wish I could tell you that, but I'm afraid you have some floor replacement to do.
Mudd is offline   Reply With Quote
Old 01-15-2009, 11:08 AM   #3
Floorwizard's Avatar
Do you have the exact same product as what was first installed (existing)?
Floorwizard is offline   Reply With Quote
Old 01-15-2009, 03:32 PM   #4
floorwizrd..I do have the exact same product....i purchased 3 extra boxes during original instal in case I needed to replace or add any.
Fatboy
Old 01-15-2009, 03:36 PM   #5
Well you can remove as many planks as needed and start with new ones as long as they are not glued. The question is weather or not it will finish up with a full plank when complete.
got pics?
Old 01-15-2009, 03:58 PM   #6
floorwizard....it is not glued and I don't remind replacing a few rows from one end of the house to the other, I just don't want to take all of it out from the wall removal point all the way to the end of the house. essentially, can I put in say two rows form one end to the other if the house with existing being on both sides of open area. I thought I could angle up the existing side and the newpiece and then force down nto place????
Old 01-15-2009, 05:02 PM   #7
Depends on the locking mechanism but usually that will not work...you will need to do much more than that. the last plank will be much like a single plank replacement and is very hard to do. If you can unclick and reclick it takes more time but is much easier.
Maybe someone else can go into it further for you.
Tags
flooring , installation , laminate floors
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
Installing laminate around doors??!! RonR Building & Construction 1 12-30-2007 02:08 PM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-17-2007 11:18 PM
