Installing Interior Basement Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 09:07 AM   #1
installing interior basement walls
I have a small 500 sq ft basement I am fixing up. I have laid the Platon subfloor down, insulated the concrete walls and have framed walls along the exterior which will be insulated.
The concrete floor slopes about 3 inches from the concrete walls to the drain area. I plan to secure the Platon subfloor right over the entire concrete floor and will correct the sloping by shimming the plywood floor to level.
My question is the interior framed walls for the bathroom. Should the 2x4 walls be secured atop the Platon subfloor, screwed into the concrete or should I level the plywood floor and attach the 2x4 interior walls to the plywood, not screwed to the concrete.
any help would be appreciate, if photos will help let me know.
mayan2012 is offline   Reply With Quote
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
Question about installing XPS insulation in basement Apollo276 Insulation 20 07-04-2011 02:22 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 08:43 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
