Installing Hardwoods, Cant Locate Studs - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 05:07 PM   #1
Smile
Installing hardwoods, cant locate studs
Hi I am attempting my first DIY project as a new homeowner - installing 3/4" mahogany floors. I have the old floors torn up, my baseboards have been removed and thankfully I have a nice, thick, plywood sub floor underneath. But without tearning up the plywood I dont know where my studs are.
1. Can I simply nail the hardwoods into the plywood instead of the studs?
2. I purchased some heavy duty roll on roofing paper as my buffer between the sub floor and the hardwoods, is this sufficient?
3. Can I just place a nice, baseboard/trim over the hardwoods, and not use quarter round? The old floors I tore up didnt have any quarter round and they looked just fine.
Any feedback would be really appreciated. Thanks everyone!
GlennM515 is offline   Reply With Quote
Old 06-28-2011, 05:21 PM   #2
PRO
1. Yes
2. No
3. Sure, but it's not going to look good.
BrandConst is offline   Reply With Quote
Old 06-28-2011, 05:22 PM   #3
woodman58's Avatar
Yes, but you can find the studs by looking to see where the nails are. They will be in a line with the studs.
Yes
Yes, but you need to make sure that you leave at least 3/8 inch (should be 3/4") gap at the walls. If you leave a 3/8" gap you will have to cut out the bottom of the dry wall. to allow for the 3/4" space. Make sure and acclimate the wood.
woodman58 is offline   Reply With Quote
Old 06-28-2011, 05:29 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
woodman58:>>> "Yes, but you need to make sure that you leave at least 3/8 inch (should be 3/4") gap from the edge of the flooring to the walls. If you leave a 3/8" gap you will have to cut out the bottom of the dry wall. to allow for the 3/4" space. Make sure and acclimate the wood."
Sorry woodman58, I modified your statement a little, I couldn't sleep tonight if I hadn't.
XXX
Old 06-28-2011, 05:33 PM   #5
woodman58's Avatar
No problem! Thanks Bud
The Following User Says Thank You to woodman58 For This Useful Post:
Bud Cline (06-28-2011)
Old 06-29-2011, 06:27 PM   #6
Thanks everyone, these comments are really helpful!
One follow-up question...if I shouldnt use the roll on roofing as my barrier, what should I place between the subfloor and hardwood?
Thanks!
Old 06-29-2011, 07:40 PM   #7
woodman58's Avatar
You can use roofing felt. I use 15#. It is suppose to be a moisture barrier but, it makes a better dust barrier.
Tags
base board , hardwood floor , studs
Stud spacing when installing enclosure not enough az_r2d1 Building & Construction 23 03-26-2011 10:01 PM
attaching tub surround directly to studs? upslims Building & Construction 11 04-07-2009 09:39 AM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
Attaching Studs to Concrete/Which way mjkpainting Carpentry 17 12-30-2008 10:02 AM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 04:50 PM
