Installing Hardwood, Uneven Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 12:46 PM   #1
Installing hardwood, uneven floor
I am just about to start installation of hardwood however I have one problem. As you can see in the pictures there is uneven floor at the OSB joint at the master bedroom entrance. It seems like there is a beam right at the entrance and trusses are installed at the lower level if compared to the beam. There is probably 1/4" gap (at the most) between hardwood board and OSB subfloor. As I will be installing hardwood perpendicular to the trusses (marked in red), what can I do to reduce the bump?
Is sanding down the only way I can do it?
Installing hardwood, uneven floor-img_04201.jpg   Installing hardwood, uneven floor-img_0421.jpg
Denisrus is offline   Reply With Quote
Old 07-03-2012, 05:40 AM   #2
Remodeling Contractor
remove the OSB, trim the joists and place the OSB back with glue and screws.
Hardwood Floor Buckling klappjack Flooring 6 10-04-2014 12:21 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 11:58 PM
Sanding methods for uneven hardwood floors inquisitiveblue Flooring 3 08-05-2011 11:49 AM
Hardwood floor installing question duha79 Flooring 6 05-14-2010 05:44 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
