Installing Hardwood Next To Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2007, 11:58 PM   #1
Installing hardwood next to carpet
I will be installing hardwood in a room with three walls. The fourth side will be met with carpet. I plan to start at the far wall and work to where the carpet will be. How do I end the last row of planks? I was told that in a standard installation, with the wood meeting 4 walls, I would face nail the final row. But in this case, it will meet carpet and will not be covered with baseboard. Also, do I need to cut off the tongue from the last row?
Thanks.
digexpressions is offline   Reply With Quote
Old 12-05-2007, 06:59 AM   #2
Rewards Points: 150
If it meet carpet in an open doorway you should be able to use the nailgun all the way to the end.
I usually rip off the tongue of the final row and bevel the edge if its meeting carpet
mike costello is offline   Reply With Quote
Installing Hardwood Floor Frank Pantusco Flooring 1 10-26-2007 11:17 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Need advice on installing indoor/outdoor carpet Krichton Flooring 1 06-27-2007 04:36 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
