Installing Hardwood Next To Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2007, 11:58 PM   #1
Installing hardwood next to carpet
I will be installing hardwood in a room with three walls. The fourth side will be met with carpet. I plan to start at the far wall and work to where the carpet will be. How do I end the last row of planks? I was told that in a standard installation, with the wood meeting 4 walls, I would face nail the final row. But in this case, it will meet carpet and will not be covered with baseboard. Also, do I need to cut off the tongue from the last row?
Thanks.
digexpressions is offline   Reply With Quote
Old 12-11-2007, 07:43 PM   #2
How is the carpet attached?
redline is offline   Reply With Quote
Old 12-12-2007, 06:54 PM   #3
FatAugie's Avatar
Alot of times they'll make a finish trim piece that's got the grove on one side and either tapered down or bull nosed or something to finish the end off.
FatAugie is offline   Reply With Quote
Installing Hardwood Floor Frank Pantusco Flooring 1 10-26-2007 11:17 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Need advice on installing indoor/outdoor carpet Krichton Flooring 1 06-27-2007 04:36 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
