Installing Hardwood Floors - Is Floating The Floor Required? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 07:28 PM   #1
Installing Hardwood Floors - Is floating the floor required?
I am installing exotic engineered hardwood flooring in my office. One vendor stated that the floors would need to be leveled prior to installation and that all concrete floors had to be leveled prior to glueing down the floors. Is this true?
Last edited by DrTude15; 11-21-2012 at 06:15 PM. Reason: I meant to state leveling the floor not floating the floor
DrTude15 is offline   Reply With Quote
Old 11-19-2012, 11:22 PM   #2
Rewards Points: 13,450
Sure he did not mean leveled?
Why not go on the manufactures web site and check out there install info and get the info from the people that are going to be warrentying the flooring.
Not big fan of glued down engineered floor, may want to take a look at there directions on how to install it as a floating floor.
DrTude15 (11-21-2012)
Old 11-20-2012, 01:01 PM   #3
Rewards Points: 264
I am also thinking your installer was referring to leveling the floor. If you have a level concrete slab this is not always necessary.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Old 11-20-2012, 03:49 PM   #4
The concrete will need to be flattened not leveled.
Before I paid someone to flatten he floor I would want a MVER and possibly calcium chloride test.
1950home is offline   Reply With Quote
Old 11-21-2012, 06:13 PM   #5
Yes the correct terminology was leveling the floor not floating. Thanks guys for the feedback. I understand now. I will have to ask if they will glue down the boards or float the floor. I did a little more reserach after posting the question. Thanks again for the help.
The Following User Says Thank You to DrTude15 For This Useful Post:
oh'mike (11-21-2012)
Old 11-26-2012, 10:30 AM   #6
Rewards Points: 150
It's true if your floors aren't level enough.
The flooring manufacturer usually has a subfloor level specification (e.g. 1/4-in over 10 ft or 1/8-in over 6 ft, etc.). For engineered flooring in a glue-down installation, I would think that the level specs would be pretty tight. Otherwise, the joints could fail.
If I were given two quotes for a job such as this, and one guy looked hard at the floor and said he'd level it first, that would be the person I'd go with. As a customer, you don't want call backs any more than the installer does.
zakany is offline   Reply With Quote
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 11:20 AM
How to Recoat (Sandless Refinish) Hardwood Floors RhodesHardwood How To Guides 11 03-12-2014 11:42 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Installing hardwood floors helpless handyman Carpentry 10 04-09-2007 09:23 PM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 09:06 AM
