Installing Hardwood Flooring In The Hall Way - Flooring - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 10:11 PM   #1
installing hardwood flooring in the hall way
I will be installing Oak hardwoord in two hall ways that are 90 drees to each other. What are my options for transition between the two. One hallway starts at my entry and then you would turn at the end of it to go down the other which goes to the bed rooms. There is a pocket door at the start of the hall way to the bed rooms.
Thanks for your help.
Allan
tool time Allan is offline   Reply With Quote
Old 12-08-2009, 06:09 AM   #2
Several methods: just butt one hall to the other, simple, it works, but may not look right. Weave the two together, takes longer. Cut all joints in the weave at 45deg. Insert a bisquit at joints for stability.
Old 12-08-2009, 08:33 AM   #3
msv
Hardwood pro
msv's Avatar
if the hallways are level and communicate, why not install the wood the long way on each one and have the direction change under the door? that way it will look like two distinct spaces, especially with the door being there..
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Old 12-10-2009, 10:23 PM   #4
how about doing a small decorative section in the transition area, where you turn the wood on an angle, create a small mosaic area or something to show it was intentional to dress up the transition area?
Allison1888 is offline   Reply With Quote
Old 12-11-2009, 05:25 AM   #5
You do not have to change the direction of the hardwoods at the hallway.
Many times we install the hardwoods the same direction throughout an entire level. If you do this make sure you take some extra time in getting a baseline that is square with the front door and the hallway wall.
Hopefully when the house was framed originally the walls are square. IMO nothing looks worse than a piece of hardwood that has to be ripped at an angle to meet a wall but sometimes it is unavoidable do the walls be askew.
If you want to change directions at the door it will look something like these pics. On this job we started with the piece across the opening to the dining room. That way we had the groove of the first piece in the dining room and the tongue on the end of the boards in the foyer to lock the floors together. No need for a biscuit doing it this way.
installing hardwood flooring in the hall way-dsc03073.jpg   installing hardwood flooring in the hall way-dsc03080.jpg
AtlRemodeling is offline   Reply With Quote
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
Installing Prefinished Hardwood Flooring Around Kitchen Island bioman Flooring 4 03-25-2009 06:18 PM
Installing Hardwood Flooring selical Flooring 4 10-24-2008 10:45 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
