Installing Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 12:57 PM   #1
Rewards Points: 113
installing hardwood flooring
When is best time of year to install hardwood flooring. How many days should flooring acclimate indoors. do i need a moisture meter.
EFTHIM is offline   Reply With Quote
Old 08-21-2012, 07:59 PM   #2
I don't think there is a best time of year to install hard wood flooring.
Different brands and types of flooring request different amounts of time to acclimate. The flooring should be spread out through the areas that are going to be floored (not just put in the garage). Lets just say a case of 3/4” 20 square feet is around 56 pounds; a 2 bedroom house at 900 square feet would weigh in over 5,000 pounds.
Moisture meter is a must IMO. Best to check the moisture before ordering the flooring around out side walls and bathroom walls. You still need to test after old floor comes out.
1950home is offline   Reply With Quote
Old 08-21-2012, 10:14 PM   #3
Rewards Points: 13,446
Time of year means nothing, it's temperture and humidity that's important.
Need to be testing the floors not the walls as the other poster suggested.
Is this flooring going over a home with a basement or crawl space?
Old 08-22-2012, 04:20 AM   #4
I meant to check the moisture of the floors around the outside walls, bathroom, and kitchen.
Old 08-23-2012, 11:40 AM   #5
Rewards Points: 113
Optimal moisture content for installing hardwood floor
What is optimal moisture content between hardwood and sub floor? Thanks
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 05:25 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
New to installing Hardwood Flooring Quicksilver Flooring 6 05-17-2011 06:59 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
