Installing Hardwood Floor Over Crawl Space - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 11:43 PM   #1
Installing hardwood floor over crawl space
I am installing a hardwood floor over a crawl. I removed the old carpet and tile, there was partical board that came up with the tile. I was planning on replacing the particle board that was removed with plywood to make it all flush again, however, I spoke to an installer at the flooring store and he stated to just remove all the particle board. I did that. Now underneith that is 1 by 8 planks on top of the floor joists. the planks are not tight and have gaps up to a 1/4" in places. He stated to just lay 30 lbs felt paper down over the sub floor ( 1x8 planks) and I'll be fine. So my concerns are that I will be nailing in between the gaps in the planks, since I am running parallel with them...he stated to snap lines over the felt paper and nail into the floor joists. Do I need to lay plywood over the 1 bys? Or is he correct? second, is the felt paper a strong enough vapor barrier over a crawl? I wouldnt think so. Thanks
klaus135 is offline   Reply With Quote
Old 04-25-2012, 01:05 AM   #2
Normally those old planks are just fine to go over. However, we would make this decision based on the height of any adjoining flooring and the condition of the subfloor.
RhodesHardwood is offline   Reply With Quote
Crawl Space Insulation - Will this work? pjh3939 Insulation 4 12-03-2011 10:36 AM
Crawl Space Questions (with pics) burnt03 Building & Construction 4 11-04-2009 07:44 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 02:55 PM
