Installing Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-20-2007, 02:39 PM   #1
I am about to install 2200 sq ft of hardwood floor in my restaurant. What is the best way to put it down. About half is going on a very dry concrete slab and the rest on a wood platform. Because this is a Bar I am concerned about water(SPILLED DRINKS)seaping underneath the planks and causing damage. I was told to glue the planks down and then nail and i was told to just glue the planks down only. Please advise the best way to do this. I am in the Virgin Islands and can not find a contractor to do it so I am stuck doing it myself.
Thank You
Frank Pantusco is offline   Reply With Quote
Old 10-26-2007, 10:17 PM   #2
Floorwizard's Avatar
is this a solid or engineered wood floor?
how thick is the wood?
how wide are the planks?
this info will help.....
Floorwizard is offline   Reply With Quote
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 09:06 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
