Installing Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 08:36 PM   #1
Rewards Points: 528
installing hardwood
What size staples/nails are best to use when installing 3/8 engineered hardwood by Mohawk?It has a regular 3/4 subfloor and i will be using a mini flooring nailer/stapler to install them.Also will staples hold better or are nails the way to go?
Any info is appreciated.
hidden1 is offline   Reply With Quote
Old 03-02-2013, 11:47 PM   #2
Rewards Points: 13,300
And what does it say on the Mohawk web site to use?
There the ones that will be warrentying the floor.
Old 03-03-2013, 01:54 AM   #3
Rewards Points: 528
I can use either staples or flooring cleats or glue method.
Old 03-03-2013, 09:38 AM   #4
DIY staff
Rewards Points: 7,174
I've never installed that---but I did see an article that showed serious puckering or dimpling caused by staples that were set to deep and bent the edge of the board enough to show on the shiny surface--
-so. do spend some time setting the nail/staple depth properly----
Old 03-11-2013, 12:17 PM   #5
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
diagonal nails that are nailed into the groove of the boards. You need to do this by force so that one slat is tightly fixed to the other slat
harrymontana is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 01:45 PM
Installing Hardwood Floors kje7713 Flooring 7 02-16-2013 07:46 PM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 10:35 PM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 04:10 PM
Installing Hardwood Floor Frank Pantusco Flooring 1 10-26-2007 11:17 PM
