-   -   installing hardwood (http://www.diychatroom.com/f5/installing-hardwood-173427/)
hidden1 03-02-2013 07:36 PM
installing hardwood
152 Attachment(s)
What size staples/nails are best to use when installing 3/8 engineered hardwood by Mohawk?It has a regular 3/4 subfloor and i will be using a mini flooring nailer/stapler to install them.Also will staples hold better or are nails the way to go?
Any info is appreciated.
joecaption 03-02-2013 10:47 PM
And what does it say on the Mohawk web site to use?
There the ones that will be warrentying the floor.
hidden1 03-03-2013 12:54 AM
152 Attachment(s)
I can use either staples or flooring cleats or glue method.
oh'mike 03-03-2013 08:38 AM
I've never installed that---but I did see an article that showed serious puckering or dimpling caused by staples that were set to deep and bent the edge of the board enough to show on the shiny surface--
-so. do spend some time setting the nail/staple depth properly----
harrymontana 03-11-2013 11:17 AM
diagonal nails that are nailed into the groove of the boards. You need to do this by force so that one slat is tightly fixed to the other slat
