Old 10-25-2009, 09:08 PM   #1
Default installing hardie backer board
hi my name is Don and i am trying to find out if i use modified thin set instead of unmodified thin set between the plywood subfloor and the backer board will i encounter any serious problems down the road
alamojo42 is offline   Reply With Quote
Old 10-25-2009, 09:35 PM   #2
Residential Remodeler
You would want to use modified as the additives in it will allow it to cure and stick to the plywood, whereas unmodifed will not adhere to plywood.
CookeCarpentry is offline   Reply With Quote
Old 10-25-2009, 10:21 PM   #3
Tileman-Manufacturers rep
Hi Alamo,
Hardie tells you to use either modified or unmod to install the board, and modified only to install the tiles. You are not necessarily trying to bond the board to the subfloor. The thinset under is there to support the board so there is no movement. Problems down the road? Removing it in 20-30 years.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
installing backer board over particle board bob mac Flooring 5 06-15-2009 07:01 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 06:55 AM
Hardie backer board DXS General Discussion 2 03-17-2009 07:40 PM
installing hardy backer board around a tub mrombs Building & Construction 4 08-06-2008 11:31 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-07-2006 12:50 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
