Installing Glue Down Engineered Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 09:24 PM   #1
Installing glue down engineered floor
I am installing a glue down floor over concrete. the concrete has been leveled and the temp of the concrete is about 70degrees. The problem is that the glue does not seem to be adheering to the boards or the concrete. I spread the glue and waited about 10 minutes (per directions) but the floor planks seem to be popping up. I have noticed some of the flooring planks are bowed a little, but i assume the glue, if working properly would bond and hold the planks down. HELP
brad4499 is offline   Reply With Quote
Old 03-11-2008, 07:29 AM   #2
Rewards Points: 264
what brand and type of glue are you using, and how are you applying it?
moneymgmt is offline   Reply With Quote
Old 03-11-2008, 10:05 AM   #3
I am using Bruce Adhessive and using a 3/8" v grooved trowel. Do you think the temp of the floor and room may be an issue? Thanks for any advice you can give.
Old 03-11-2008, 12:50 PM   #4
Rewards Points: 150
will the planks lay flat on the floor without glue?
Does your floor pitch and roll?
mike costello is offline   Reply With Quote
Old 03-11-2008, 04:38 PM   #5
Some planks lay flat, others have slight bows in them. The floor has been leveled and seems to be flat and sound. I have been told to lay sand bags on the planks after gluing them so they don't pop, what do you think?
Old 03-11-2008, 10:01 PM   #6
remodeling pro
Originally Posted by brad4499 View Post
them. The floor has been leveled and seems to be I have been told to lay sand bags on the planks after gluing them so they don't pop, what do you think?
Ask the person giving that advice if he is going to pay for the repair when those areas start popping loose a few months down the road. You need to determine if the problem is in the concrete, if so it needs to be accurately leveled; or if the flooring material itself is bowed , in which case you should return it, as that would be the result of improper stacking of the material at the warehouse.
troubleseeker is offline   Reply With Quote
Old 03-12-2008, 09:54 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is this installation below grade?
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Why is my living room cement floor covered with black glue? sil Flooring 7 10-29-2007 10:03 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
