Installing Folding Closet Doors On Floating Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2015, 04:35 PM   #1
On the Road Less Traveled
The Jeep Driver's Avatar
Rewards Points: 91
Question
Installing Folding Closet Doors on Floating Laminate
I took the carpet out of the bedrooms, and laid a floating laminate wood floor. How do I reinstall the folding closet doors? Specically how do I attach the track to the floor? I think if the screws secure the laminate to the subfloor it could lead to gapping as the boards expand and contract.
The Jeep Driver is offline   Reply With Quote
Old 04-11-2015, 06:19 PM   #2
Property Mgt/Maint
Rewards Points: 1,236
I think I would use short screws and not go into the sub. Cutting the float and anchoring to the sub directly would work good but probably look bad. What is the distance across the floor to the apposing wall. And how much distance on either side of the closet. And is there a pad under the floor, floor thickness?
Yodaman is offline   Reply With Quote
Old 04-11-2015, 06:49 PM   #3
Rewards Points: 91
I don't think short screws would hold the doors because...
...the laminate is only 5/16" (8 mm) thick. There is a heavy pad as well, I don't remember the thickness of it.
12 ft.
There are 2 closets (4 ft. each door) and the entry door (28") on that wall... does that answer what you were asking?
Old 04-11-2015, 07:02 PM   #4
Rewards Points: 91
Will I have to drill pilot holes through the laminate flooring and into the subfloor, then drill a larger hole only through the laminate?
Old 04-11-2015, 07:40 PM   #5
Property Mgt/Maint
yes help full. Do we have according folding or bifold, 2 panel on each side hinged each side? Reason I ask do we need to attach the base track?
If we need the track, we need to attach it with standoffs (spacers or washers) to prevent us from anchoring the floater. Obviously will need a clearance hole or slot for the standoff. My first mat'l choice for making a standoff spacer would be PVC
Have you considered a french door setup?
Old 04-11-2015, 08:06 PM   #6
Rewards Points: 13,694
Sorry, really bad suggestion.
There should have been a transition strip in the middle of the door opening.
rusty baker (04-11-2015)
Old 04-11-2015, 08:47 PM   #7
Property Mgt/Maint
Not ideal but a workable solution from where we are at. Maybe its not too late to pull up from the closet to the doorway and install a transition pc. If not, will need to cut in place either way.
Old 04-11-2015, 09:18 PM   #8
Rewards Points: 91
No transitions at all, the floor runs continuous through 3 rooms and a hallway.
The doors are bi-fold.
Old 04-11-2015, 09:32 PM   #9
Property Mgt/Maint
So w/bifolds hinged on each side are we certain that we need the bottom track?
"No transitions at all, the floor runs continuous through 3 rooms and a hallway."
What is the longest continuous run? Glue your seams? Long runs can pull seams apart with expansion/contraction
Old 04-11-2015, 09:41 PM   #10
Rewards Points: 91
Yes, these need the bottom track. Can't find a make/model on them.
Off-hand I don't know the length, but it's not long enough to worry about separation due to length.
Old 04-11-2015, 10:00 PM   #11
Property Mgt/Maint
http://www.homedepot.com/p/Zamma-Gle...1634/204491123
I think Joe is referring to a pc like this or similar to, This can be fastened directly to the sub while stilling allowing the floor to float. And will give you a surface to mount your track on.
Old 04-11-2015, 10:07 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
The bifold bottom brackets I have seen are L shaped, attach it to the jamb and not the floor.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
joecaption (04-12-2015)
Old 04-11-2015, 11:59 PM   #13
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
Less than 35 feet?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-23-2015, 11:24 AM   #14
Rewards Points: 91
I know the style you mean, these have a track at the top and the bottom. They are mirrored, I am guessing the weight makes it necessary to have the track and not the L brackets.
Originally Posted by rusty baker View Post
Less than 35 feet?
Yes, 30 ft.
There is nothing wrong/incorrect with the floor install itself. Eliminating transitions makes for a "smoother" or "more flowing" look.
I installed the tracks using the method I mentioned below; marked the locations of the tracks screw holes, drilled pilot holes, then set a depth-stop on a larger bit to make a expansion "gap" around the screws. The track can't move, but the laminate can still expand/contact as needed.
Old 04-23-2015, 02:33 PM   #15
Rewards Points: 112
"Eliminating transitions makes for a "smoother" or "more flowing" look."
That's true, but it can also cause the laminate to buckle.
Tags
closet , doors , folding , laminant flooring
Painting newly installed closet doors drsunny Painting 5 01-11-2015 08:46 AM
how to remove closet sliding doors young707 Windows and Doors 8 08-04-2013 06:07 PM
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 10:09 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Closet Doors for non standard closet dimensions jherschel Carpentry 7 02-22-2008 04:45 PM
