Old 02-05-2011, 09:12 PM   #1
Unhappy
Installing floor tile but don't want grout gap to turn black overtime
In the process of having new floor tile installed. We looked at porcelain tile and regular ceramic tile. Due to budget restraints I think that we are going with the least expensive (regular ceramic tile). We're tiling the whole house.
My question is the drawback with tile is that the grout always turns black overtime with the dirt. The porcelain that we saw today was one that would be installed as marble and therefore there would not be a wide grout line but again this is too expensive.
Any recommendations so that the grout area doesn't turn black with basic ceramic tile? We are getting light colored tile.
gatorade is offline   Reply With Quote
Old 02-05-2011, 11:52 PM   #2
Tileguy
JazMan's Avatar
Hi,
Too expensive? What price range are you looking at? How much do you need? Doing the work yourself?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-06-2011, 08:06 AM   #3
Super Moderator
There are stain free grouts available----Epoxy and Quartz lock---But the run about $1.00 per square foot
Pay now or live with stained grout---Mike---
oh'mike is online now   Reply With Quote
Old 02-06-2011, 10:42 PM   #4
You get what you pay for in a floor. I say this with a smile. Porcelain (or ceramic) as the tile and use an epoxy based grout. It is the same grout used around pools, it never has to be sealed and is somewhat immune to mold and mildew (the discolouration you mentioned). The drawback to using epoxy is that it is hard to work with and you have to be quick and accurate with the process. The advantage is the floor will never have to be sealed, resistant to spoore growth, waterproof, and extremely AwSome when heat is used along with the project.
EddyS is offline   Reply With Quote
Old 02-07-2011, 12:13 AM   #5
two options: use a high quality penetrating sealer on the grout and maintain a rigorous cleaning/sealing schedule(NOT). or use an epoxy grout. Costs more up front but worth the money. color stays true for a long time and RESISTS molding, staining, yellowing.
acglobal is offline   Reply With Quote
black glue installing carpet over it brucerbnsn Flooring 1 05-27-2010 01:59 PM
botched grout/tile job hello1 Tiling, ceramics, marble 10 09-29-2009 05:48 PM
Do I need to grout fireplace tiles? xiard Remodeling 4 04-17-2009 08:19 AM
installing a dimmer switch from an old switch wilsonfrench Electrical 7 01-11-2009 02:05 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
