Installing Floating Floor Over Squeaky Wood Floor- Rip It Up? (Q3) - Flooring - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 12:28 PM   #1
Artisanette
Installing floating floor over squeaky wood floor- rip it up? (Q3)
Hi again-
Here's the other big question: the existing floor in my living room is oak t&g (5/8") over a diagonal plank sub-floor over joists. The home was built in 1955 and the floor has been carpeted since I bought the house 5 yrs ago.
When I pulled up the carpet, it revealed a pretty damaged hardwood floor-- hard to imagine what they did to it to ding it up that bad! Anyway, the major issue with the floor is that it squeaks badly and I'd like to take care of that before I lay the floating cork floor.
So my options are:
1) quick & dirty: locate the joists, run 3" screws through the existing floor and subfloor, which should pin down both the wood floor and the subfloor to the joists. But, yes, I know I know, wood expands and maybe this is a bad idea
2) not so quick but a lot dirtier- rip up the old wood floor, screw the subfloor back down to the joists (after 53 years a lot of the nails have worked loose, I'm sure), then glue/screw a new layer of 5/8" (OSB or plywood? opinions sought) on top of the sub-floor, THEN lay the floating floor.
3) Anything I haven't thought of?
PS- the basement is finished and I'm not interested in ripping up the ceiling to fix squeaks from below. Topside improvements are going to have to be good enough!
looking forward to your answers and thoughts-
Chris in SLC
"Artisanette"
cee2ski is offline   Reply With Quote
Old 02-09-2009, 07:23 AM   #2
Remodeling Contractor
Screw it all down and if it is not squeaking you are ready to go.
Tags
squeaky floor , sub-floor
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
