The floor is plank subfloor, with 3/4" OSB on top. I plan on laying a vinyl sheet over the OSB, but was wondering if I should add some short of waterproof layer on top of the OSB.
Still going to need an underlaymant. With out it ever gap, nail will show through and the flooring will not stay stuck down.
1/4 underlayment rated plywood will work.
Not louon!!!
It gets layed so the seams do not line up with the seams below, no glue, no spacing between the sheets.
I use a pneumatic narrow crown staple gun to install it set on touch and go.
Only takes about 1 min. to install per sheet. It needs to be fastened every 4" on the edges and 6 to 8 in the field.
Any flaws or gaps need to be filled or there going to show through the sheet flooring.
Do you like the look of the texture of the OSB? Because after about a year or two your going to be seeing that pattern in your vinyl......
BTW....any display you see at HD is just that....a display....people are not walking on it every day.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
