Installing Engineered Hardwood - Subfloor Question - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 03:19 PM   #1
Installing engineered hardwood - subfloor question
Hello everyone,
I’m in the middle of building my first house, doing most of the work myself. I’m finally at the stage where I can start thinking about flooring. My girlfriend and I both like the look and price of chestnut bamboo engineered flooring at Home Depot.
http://www.homedepot.ca/webapp/wcs/stores/servlet/CatalogSearchResultView?D=980486&Ntt=980486&catalo gId=10051&langId=-15&storeId=10051&Dx=mode+matchallpartial&Ntx=mode+ matchall&N=0&Ntk=P_PartNumber
My question is do I need to install another layer of plywood flooring on top of my subfloor (5/8" plywood sheathing, on engineered floor joists @16 o.c)? Some people are telling me I can install this product directly on top of the existing plywood, and others are telling me to install ” to 3/8” plywood through out my house, and then install my flooring on top of that. The existing plywood is in good shape despite taking a lot of rain. The flooring can be installed a number of ways, I plan on floating for ease of installation. All the installation instructions say on the manuf. Website is
http://www.trilliumhardwood.com/instructions.html
"Subfloors must be flat: Wooden subfloors: plywood, OSB or boards must be flat, high or low areas exceeding 1/4” per 10’ must be corrected. Sand down high areas, fill low areas.
Any help would be greatly appreciated. I plan on buying it this saturday.
benr is offline   Reply With Quote
Old 01-21-2011, 06:06 PM   #2
KCB
I recomend a minimum of so do alot of professionals .
KCB is offline   Reply With Quote
Old 01-21-2011, 06:15 PM   #3
Rewards Points: 200
So do i . Run the length of the plywood in the same direction as the subfloor . Just overlap it one joist . The floor as to be flat 1/8" in 6' or 3/16" in 10'
Floor Doc is offline   Reply With Quote
Old 01-22-2011, 06:01 AM   #4
KCB
Id just reverse it from the pattern you have now or run it the opposite direction.Where you dont hit a joist use glue(liquidnail) and screws . Depending on your budget you could screw it all or alternate nail/screw .
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 09:35 PM
installing 3/8" engineered bruce hardwood maple floor 3" huskertedd Flooring 2 11-22-2008 07:41 AM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 03:10 PM
Installing floating engineered hardwood in entrance and stair stringers bluedisc22 Flooring 3 01-25-2008 02:03 PM
