Installing Engineered Hardwood Flooring Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 02:59 PM   #1
Lightbulb
Installing engineered hardwood flooring over concrete
I am installing engineered hardwood in my living room and hall this wood will be glued to the concrete. The living area has 2 entries on the same wall with the fireplace(6') between them. At one of the entries the concrete is a little bit higher than the other side.(This is not the transition this is the concrete that I will insall the floor on) Does any one have a suggetion on this? Or on concrete sanding?
deborahs is offline   Reply With Quote
Old 07-29-2009, 08:50 PM   #2
Floorwizard's Avatar
Floating this floor would be a better idea. Float it over 6 mil poly film.
Use a t-molding where there are 2 different heights...that may work depending.
Floorwizard is offline   Reply With Quote
Old 07-30-2009, 10:38 AM   #3
Hello Floorwizard
I considered floating but I don't like the echo in the room when you walk on it. The room is very large with high ceiling and I thought the glue down method would make the flooring sound more solid. I guess I did not make my question clear I understand the T -molding for transition but the concrete where I will lay the floor is higher on one side of the fireplace than the other. On one wall there is and entrance, 6' of fireplace and the other entrance.
Thank you so much for your reply
Debbie
Old 07-30-2009, 10:35 PM   #4
Go ahead & glue it. Tape down a piece of plastic for 48 hours. If you get moisture, put down an elastomeric coating first.
pinwheel45 is offline   Reply With Quote
Installing Prefinished Hardwood Flooring Around Kitchen Island bioman Flooring 4 03-25-2009 07:18 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
Engineered flooring, will it settle???? rdmccaw Flooring 7 04-16-2008 05:31 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
