Installing An Electric Radiant Heating Pad And Tiling Over A Concrete Slab Floor Of A Breezeway - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 03:41 PM   #1
Installing an electric radiant heating pad and tiling over a concrete slab floor of a breezeway
Does the concrete slab have to be insulated, and should the walls also be insulated?
Carolyn Gray is offline   Reply With Quote
Old 01-21-2012, 06:43 AM   #2
Remodeling Contractor
To reduce the energy costs of operating the heated floor the slab should have 2" foam under the cement and the walls to be insulated to R-19, ceiling to R-38, door to be exterior grade and weather stripped.
Old 01-24-2012, 12:42 PM   #3
Installing an electric radiant heating pad on an old concrete slab floor.
I should have mentioned that the concrete slab is part of an old breezeway that I am rehabbing. It had asphalt tile on it for about 50 years, and this is now removed. Therefore, I cannot put any insulation under the slab. What kind of insulation can I put between the top of the slab and porcelain tile? I have heard of cork insulation. Is this a good choice?
Thanks.
Old 01-24-2012, 03:19 PM   #4
no. That will not do, you do not want any flexible surface under the tile. Possible just use an electric heat mat to at least keep the tiles warm
Old 01-24-2012, 03:32 PM   #5
DIY staff
Rewards Points: 7,174
Actually,Bob--cork is an approved underlayment for tile---It is used as a sound deadener in apartment buildings under tile---
It is expensive and I doubt the extra cost would add much insulation value.
Call the maker of the heat mat and ask their technical help line---I've never used it under a heat mat--
