-   -   Installing an electric radiant heating pad and tiling over a concrete slab floor of a breezeway (http://www.diychatroom.com/f5/installing-electric-radiant-heating-pad-tiling-over-concrete-slab-floor-breezeway-130755/)
Carolyn Gray 01-20-2012 03:41 PM
Does the concrete slab have to be insulated, and should the walls also be insulated?
Bob Mariani 01-21-2012 06:43 AM
To reduce the energy costs of operating the heated floor the slab should have 2" foam under the cement and the walls to be insulated to R-19, ceiling to R-38, door to be exterior grade and weather stripped.
Carolyn Gray 01-24-2012 12:42 PM
Installing an electric radiant heating pad on an old concrete slab floor.
I should have mentioned that the concrete slab is part of an old breezeway that I am rehabbing. It had asphalt tile on it for about 50 years, and this is now removed. Therefore, I cannot put any insulation under the slab. What kind of insulation can I put between the top of the slab and porcelain tile? I have heard of cork insulation. Is this a good choice?
Thanks.
Bob Mariani 01-24-2012 03:19 PM
no. That will not do, you do not want any flexible surface under the tile. Possible just use an electric heat mat to at least keep the tiles warm
oh'mike 01-24-2012 03:32 PM
Actually,Bob--cork is an approved underlayment for tile---It is used as a sound deadener in apartment buildings under tile---
It is expensive and I doubt the extra cost would add much insulation value.
Call the maker of the heat mat and ask their technical help line---I've never used it under a heat mat--
