-   -   Installing ditra over subfloor (http://www.diychatroom.com/f5/installing-ditra-over-subfloor-130102/)
NNJ 01-15-2012 04:02 PM
Installing Ditra over plywood subfloor. As per schuler guidelines I must use modified thinset. I purchase speedset polymer modified thinset mortar. I'm not sure if this is modified ? Or shoud I take the clue on the package polymer modified to mean modified.
Thanks in advance for advice.
JazMan 01-15-2012 08:47 PM
It's modified alright. You even just said so. :thumbsup: But, you do NOT want to use that to install Ditra. It is a fast setting mortar, you do not have enough hands to work with it before it gets hard. Buy a regular modified, avoid terms such as 'speedset' - 'rapidset' or anything similar. You can install Ditra then begin setting tiles shortly after.
Jaz
NNJ 01-16-2012 12:41 PM
Thank you
Thank you for your knowledge and advice.
I did use the speedset to put the ditra down because I already had it and wanted to get rid of it. Fortunately it is a fairly small flooring project so it went down without a hitch. I used the mega bond to apply tile to the ditra.
Thanks again and Happy New year.
