Installing Ceramic Tiles On Stairs. - Flooring - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 08:54 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Installing ceramic tiles on stairs.
Hi everyone
I would like to install ceramic tiles on my stairs going down to the basement.
Presently, there are some cheap vinyl peel and stick tiles. I plan on removing them and cleaning it up. The stairs are made of wood.
Can I install the tiles right on the wood? If so, do I use the regular thinset for ceramic tiles?
Thanks very much.
yummy mummy is offline   Reply With Quote
Old 09-08-2011, 09:07 PM   #2
DIY staff
Rewards Points: 7,174
Stairs move to much for a safe installation---
I've done it ,long ago, without a failure----however I would never do that again---Just dumb luck that it worked.---Mike----
Old 09-08-2011, 09:07 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yummy Yummy Yummy!
Now you have entered into the Twilight Zone.
First describe how these steps are constructed in every detail.
What are they made of dimensionally?
Do they have closed risers?
What size are the stringers?
Is there a center stringer?
What size are the treads?
Are the treads set on notches or are they cleated?
Nailed or screwed?
Steps are not usually a good thing to put tile on.
Old 09-08-2011, 09:25 PM   #4
Hi Bud!
So nice to hear from you, and you too mike.
Not a good idea? Then I guess I will live with the vinyl, and maybe replace with better vinyl....... We use these stairs to enter the house in the winter, so I thought if I put something like ceramic it would be really easy clean up.
The risers are closed. What the hell is a stringer? OMG I sound stupid...
Notched, cleated????? All I know is that they are wood approx. 2 inches thick. There is no railing on either side. They are just steps against 2 walls, if that makes any sense..... Only 6 steps.....
Old 09-08-2011, 09:26 PM   #5
Bud, you got me hooked on tiling and I just want to tile anything around this house.......
Old 09-08-2011, 09:32 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well...I wish you would look around and find something else to put tile on.
Wooden steps are super problematic and often have many issues. It can be done but only under the best of circumstances.
How about the fridge? No, nevermind that isn't a good idea either.
Old 09-08-2011, 10:43 PM   #7
Ok, if the best tile expert tells me no, then no, I won't do it.
I will remove the old peel and stick and put some better quality vinyl.
Thanks Bud. You just saved me a lot of headaches.
Your are the best!!!!!
Love ya.
Old 09-08-2011, 10:52 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And wasted money this time around.
creating a 36x15 patio out of a random mixture of ceramic tiles boogievhc Landscaping & Lawn Care 10 03-15-2011 11:06 PM
installing wall tiles clyons Flooring 1 07-23-2010 07:03 AM
Installing Ceramic Tile over thick pine Heggtveit Flooring 3 07-19-2010 10:37 PM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 02:57 PM
ceramic tiles on a diagonal pattern.... yummy mummy Tiling, ceramics, marble 37 06-22-2009 10:37 PM
