Installing Ceramic After Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 04:59 PM   #1
Rewards Points: 26
installing ceramic after vinyl
I am going to be ceramic tiling the floor in one of my bathrooms that currently has vinyl glued down over 3/4 plywood. Can I install hardi over the 3/4" plywood with some glue on it or do I have to scrape all the glue or replace the plywood? Thanks
ponch37300 is offline   Reply With Quote
Old 04-02-2009, 06:05 PM   #2
Did you remove the vinyl?
R&D Tile is offline   Reply With Quote
Old 04-03-2009, 06:00 AM   #3
ccarlisle's Avatar
Cbu has to be thinset'd in place, not glued.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-03-2009, 08:25 AM   #4
Rewards Points: 26
I understand that cbu needs thinset under it and i never meant to sound like I was going to glue it down. I removed the vinyl and some glue was left on the subfloor. Am I able to thinset over the glue that I can't scrape off or will this cause problems. I thought I might be ok since from what I understand the thinset under the cbu is just to fill any voids under the cbu? Thanks
Old 04-03-2009, 12:57 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
Carry on, good plan. Don't forget to mesh-tape the seams. Use modified thinset from here on.
Jaz
Old 04-03-2009, 01:08 PM   #6
Rewards Points: 26
Thanks JazMan. That saves alot of work!
Old 04-03-2009, 03:41 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
I see you're still online....? Go set some tiles!
Jaz
Old 04-03-2009, 05:01 PM   #8
Rewards Points: 26
I just leave the computer on while i'm working so when all the "issues" come up it's ready to post! I just set the shower pan and will start putting densshield on the walls and hardi on the floor tommorrow. I'm shure I'll have some more questions along the way. Thanks again for your advice.
Old 04-03-2009, 10:39 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
Dens on shower walls? OK, have you figured out who to build the lower part of the shower walls where the floor and wall come together? If so please xplain it to me. Have you studied their sketch?
Go to their site and find the sketch on how to build a shower. Please report back.
Jaz
Old 04-04-2009, 08:53 AM   #10
Rewards Points: 26
Jaz, I am using a plastic or PVC molded shower pan, not tiling the floor. I plan on butting the dens up to the lip on the pan and then caulking between the pan and dens. I am using dens because from what I have read it seems to be the best/easiest way to waterproof the shower besides using kerdi. I will be using redgaurd on the screws and seems. Does my plan seem ok? Thanks
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 11:01 AM
Carpet vs Laminate and Vinyl vs Ceramic Kaminberry Flooring 5 02-26-2007 07:03 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
