Installing Carpet Squares - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 03:08 PM   #1
Question
We are fixing up our spare room and will be putting down plywood to cover the old plank floor. We will be installing Design Zone carpet tiles from Lowe's. There currently is no floor molding/mop board in the room. My question is this: Do we put down mop board molding before or after we install the carpet tiles? Since the tiles are quite plush, with approximately 3/4 inch fibers, I think it would look better to put the mop board down first and then bring the carpet tiles up to it. Others offering advice suggest putting the mop board down after the carpet is in. Which is the proper procedure and which will look more proffessional? Thanks for your advice.
cwilliams5 is offline   Reply With Quote
Old 03-05-2010, 06:47 PM   #2
Tile / Stone Contractor
TileArt's Avatar
Hey cwilliams5,
On normal carpet installations the baseboard (mop board) is installed before the carpet and the carpet is tucked beneath it. Whether or not your carpet squares are plush the carpet always looks better beneath the base IMO.
I would install the carpet first then the base. Cutting carpet right up to base is a pain.
TileArt is offline   Reply With Quote
The Following User Says Thank You to TileArt For This Useful Post:
cwilliams5 (03-05-2010)
Installing built-in wall cabinet on carpet kennelm Flooring 10 09-30-2009 07:22 PM
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 05:51 PM
Installing carpet on concrete kcdave Flooring 2 02-07-2008 05:28 PM
Carpeting VS carpet squares captsam58 Flooring 1 12-13-2007 12:11 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
