Installing Carpet On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 02-06-2008, 12:53 PM   #1
Installing carpet on concrete
A lot of elementary school gyms have carpet in them now and we were thinking of doing the same thing in our basement. It looks like they use a very low pile carpet and no pad. In the office I work at they have basically the same thing and the carpet is glued to the concrete. I was wondering if you could use carpet tape instead to make it easier to change the floor later.
kcdave is offline   Reply With Quote
Old 02-06-2008, 08:43 PM   #2
you might want to try peel and stick tiles that can be places on cement floors .
PSHome is offline   Reply With Quote
Old 02-07-2008, 06:28 PM   #3
If you're even thinking about gluing carpet down with no pad, consider paying a little bit extra for an industrial grade carpet similar to what they use in large airports and office buildings.
My wife and I did this and it held up for over 15 years under normal usage.
It's even better if it's an indoor/outdoor carpet. Most of these come with a bit of rubber backing on them, so you get a little bit of padding.
One reason I suggest this upgrade is that regular carpet without a pad does not wear as well as carpet with a pad.
Randell Tarin is offline   Reply With Quote
Installing hardwood next to carpet digexpressions Flooring 2 12-12-2007 06:54 PM
Installing hardwood next to carpet digexpressions Flooring 1 12-05-2007 06:59 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need advice on installing indoor/outdoor carpet Krichton Flooring 1 06-27-2007 04:36 PM
