Installing Carpet On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 11:33 AM   #1
liscenced electrician
Rewards Points: 538
installing carpet on concrete
I got some free used carpet. Tack strip, pad and carpet. I'm going to put it in my basement (which has no moisture issues). How do I go about installing it? Use plastic concrete anchors and screws to hold the tack strip? Spray adhesive on the pad? Then pay someone to come stretch the carpet?
jimmy21 is offline   Reply With Quote
Old 11-17-2011, 12:24 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Concrete tack strip nails directly to the concrete. You can glue it to clean dry concrete with PL400 instead. .... Just about any glue will hold the pad to the concrete. Just a bead near the edges and tape the seams with duct tape.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-17-2011, 01:30 PM   #3
Rewards Points: 538
Is concrete tack strip different than regular tack strip?
Old 11-17-2011, 01:36 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Absolutely!
Old 11-17-2011, 02:24 PM   #5
Rewards Points: 538
and the difference is? Can i fasten wood tack strips to the concrete, or is there a reason i can't?
Old 11-17-2011, 02:27 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The type of fasteners used in the tackless.
Whatever you want to do - go ahead!
Old 11-17-2011, 04:15 PM   #7
Rewards Points: 12
You can pull the nails and try to glue it.
Looking for suggestions on installing concrete below tile on elevated floor lwl353 Building & Construction 17 11-01-2011 05:48 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
Installing prefinished wood over concrete Beaver Handyman Flooring 13 01-03-2011 10:24 AM
