Installing Carpet Before Trim. - Flooring - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 08:19 PM   #1
Installing Carpet before trim.
All right you pros out there. What I want to do is install my carpet before trim. I know I see many people putting the trim before carpet and have read that you are supposed to put the trim before carpet but...... Is this going to be a "MAJOR ORDEAL"? we have family coming for a week and want to do this so the room is somewhat useable.
luweee is offline   Reply With Quote
Old 05-24-2009, 08:37 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Putting the trim down after the carpet is fine. Just make sure the installer puts the tackstrip farther from the wall. If not, it wll be hard to replace the carpet in the future. And don't push the trim down hard against the carpet.
Old 05-24-2009, 09:14 PM   #3
Thanks mr. Baker.
I always love to hear from you pro's. You've been around the block a few time.
Ones that are not Pro's like to make it a big deal if you dont go by the industry norm.
By the way... any tips on staining the trim. That will be later on ... but just getting prepared.
Old 05-24-2009, 09:54 PM   #4
Remodeling Specialist
stain and urethane it before hand so you don't mess up the carpet.
Baron is offline   Reply With Quote
Old 05-24-2009, 10:10 PM   #5
Thanks baron
i was planning to do just that... but how about sanding?
You dont do this the same as furniture do ya. the trim has many small crevices.
Do you just
1. apply stain.
2. let dry
3. apply urethane
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 06:51 PM
Installing hardwood next to carpet digexpressions Flooring 2 12-12-2007 06:54 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
