#1 |
Installing Base Trim - Transition from wood to carpet???
I'm installing Base Trim in a house I just recently remodeled and since we have oak floors in the dining area it transitions to the living area which is carpet. What is the best way to compensate for the 1/2 difference and still keep the top of the trim fairly even?
Thanks, Ken Last edited by Quapaw; 03-31-2011 at 05:51 PM. |
#2 |
in most cases the carpet will be able to cover the 1/2"-3/4' gap.. if not then you may need to shave down the base in the areas with the wood.
#3 |
old guy contractor
Get the table saw out and rip 1/2 " off the bottom.
| Display Modes | |
| Carpet cleaning - sump water | n0c7 | Flooring | 17 | 08-29-2011 08:04 AM |
| Installing ceiling trim with uneven ceiling. | capslock | Carpentry | 3 | 03-21-2010 12:53 AM |
| Good equipment to use for carpet cleaning? | Beth777 | General Discussion | 5 | 08-29-2008 09:16 PM |
| Tile with a wood trim? | trick29392 | Flooring | 3 | 06-26-2008 08:19 AM |
| Base molding or carpet first??? | Dan N | Flooring | 5 | 02-01-2007 09:29 AM |
