Installing Bamboo Flooring With Brad Nailer? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 11:35 AM   #1
Installing Bamboo Flooring with Brad Nailer?
Hello all, i was curious if I can install 5/8 bamboo flooring using just a 18gauge brad nailer with 1.5" nails upon the tongues? I realize its going to be a pain to angle the nailer but i dont want to get caught up in doing this manually.
I realize people use specific flooring nailers but since bamboo is lower profile and supposedly breaks, im thinking nothing larger than 18 guage is suitable.
Also i have a vinyl floor over which im installing this which is glued down and i simply cant lift it up (there is 3/4 plywood subflooring underneath and this is above a crawl space). Can i install the flooring over the vinyl?
Thanks for your help, Cal
aaks38 is offline   Reply With Quote
Old 10-10-2008, 12:10 PM   #2
I am not going to comment on the nail issue.
But I will comment on putting your flooring over vinyl.
The key here is to make sure your transitions are not excessive. If you have a 1/2" transition then people could be tripping over it and this would be bad.
Take some of your flooring and put it on top of the vinyl next to the door into another room and see just how much of a difference there is. This will tell you if you can put the flooring over the vinyl.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-11-2008, 02:54 PM   #3
Drywall contractor
Rewards Points: 1,070
A proper transition strip between the rooms will take care of any offset as long as it isn't too much. Read the manufacturer's instructions for installation and follow them if you don't want to void your warranty.... I would not think 18 ga. brad nails would be acceptable for flooring, but I could be wrong. Can the product be installed as a "floating" floor?? No nailing involved there.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-04-2008, 09:11 AM   #4
I'm wondering if you've gotten your floor in and used a brad nailer? I'm getting ready to do the same and am hoping of saving myself the cost of a cleat nailer.
Thanks!
mikey1377 is offline   Reply With Quote
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
Nailer for flooring mpt1123 Tools 2 07-08-2008 12:24 PM
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 08:06 PM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 03:47 PM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 02:36 PM
