Installing Bamboo Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 06:29 PM   #1
Rewards Points: 12
Installing Bamboo floor
I am installing bamboo floor for the first time. I've been doing my research and some sites say that you have to leave the boards in the room of choice to acclimate them to the room. Anyone have any thoughts on this?
pjazzer is offline   Reply With Quote
Old 03-24-2013, 07:40 PM   #2
Rewards Points: 236
yes. do as they say.
though, if it is 70deg outside (where the flooring has been for a while) and 70 deg inside, not so much of an issue. its wide temp differences that you need to be concerned about.
Fix'n it is offline   Reply With Quote
Old 03-24-2013, 08:14 PM   #3
Rewards Points: 121
Absolutely needs to acclimate, for several days if possible. It's the humidity level which shrinks and expands wood the most, temperature not so much.
readar is offline   Reply With Quote
Old 03-25-2013, 05:49 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It doesn't really need the be the exact room you are putting it in unless that room is drastically different than other parts of the house. For example, you could store it in a bedroom and put it in the living room if you want, but I wouldn't store it in an unfinished basement where heat and moisture could be different than the intended install location.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
oh'mike (03-25-2013)
Old 03-25-2013, 10:19 AM   #5
Professional
UniqueWoodFloor's Avatar
You will most definitely want to acclimate the bamboo to your room before installing. The reason you need to acclimate is because wood is a natural product and will expand and contract depending on humidity. If you install it when it contains more moisture it will eventually shrink leaving gaps. The time needed to acclimate is not set in stone, however, we recommend 1 week to be safe. If you invest into a moisture meter the rule of thumb is to make sure the moisture content of the wood is no more than 4% difference from the plywood.
UniqueWoodFloor is offline   Reply With Quote
Old 04-03-2013, 02:26 PM   #6
as we are getting ready to lay out bamboo floors -- it is best to let them acclimate at least 72 hours.
urbaneve is offline   Reply With Quote
Old 04-03-2013, 03:54 PM   #7
and don't put it in the house sealed in the boxes it cam in. at least open them up so the air can get to them.
Old 04-04-2013, 08:29 PM   #8
Rewards Points: 264
I agree with Danny. I would even take it a step further and remove all of it from the boxes. Acclimating is very important.
Awoodfloorguy is offline   Reply With Quote
Old 04-04-2013, 08:39 PM   #9
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I stacked mine out of the boxes in the kitchen against the wall I was working towards. Helped me install floor as well. I have pictures in my project showcase.
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 04:48 PM
installing a bamboo stranded floating floor.. mikey1999 Flooring 2 08-24-2012 09:38 AM
Installing laminate flooring over wood floor. onenonlydano Flooring 0 03-06-2010 09:26 PM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 09:06 AM
