Installing Backer Board Over Particle Board - Flooring - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 02:06 AM   #1
installing backer board over particle board
I am presently installing bathroom tile. I have tongue and groove boards, then 3/4 in particle board. I want to install the backerboard over the particle board without removing it. I plan on using thin set under the backerboard. The flooring is solid and level and walls and cabinets have been installed over the particle board. Therefore removal of the particle board is going to be a problem. I also plan on using 1 5/8 screws to get through the particle board and into the wood floor below. Does anyone see a real problem with this plan? Also, what are the advantages of using a latex additive (modified thinset) instead of water for under the backer board? Will this keep the particle board from soaking up the moisture from the thinset? I plan on caulking around all outside edges for movement and waterproofing. Especially around the tub. When the particle board was installed (20 years ago) they put tar paper under it to keep moisture from the floor. I thought about putting down a layer of this before applying thinset and backer board. Any thoughts?
bob mac is offline   Reply With Quote
Old 06-08-2009, 03:59 AM   #2
Oldguy
Rehabber's Avatar
Particle board is NOT recommended for this application. You need to remove the particle board and install plywood 5/8" minimum thickness, 3/4" would be even better.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-09-2009, 07:32 AM   #3
What he said!!!! When particle board gets wet, and it will eventually, it returns to its basic components, sawdust, but it usually swells first. Think about that.
Old 06-09-2009, 08:26 AM   #4
ccarlisle's Avatar
Just putting down thinset on top of particleboard is a recipe for uneven floors since the water in thinset gets sucked into the particleboard. So right off the bat, you get swelling of the particleboard. Not a good combo at all.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 06-15-2009, 12:47 PM   #5
Thanks, I took your advice and removed the particle board. I will be putting down Dry Ply 3/4" plywood before proceeding. Thanks again.
Old 06-15-2009, 06:01 PM   #6
Civil Engineer
Rewards Points: 4,514
Not sure what Dry Ply is, but you are supposed to use exposure class 1 plywood (CDX is suitable). If Dry Ply is exposure class 1, you are all set.
Old 07-16-2013, 04:15 PM   #7
Thumbs up
Thanks for that topic, I find it very interesting.
DrZboczek is offline   Reply With Quote
installing hardy backer board around a tub mrombs Kitchen & Bath Remodeling 8 02-11-2012 12:00 PM
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 05:55 AM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
