Installing 3/4 Inch Hardwood In "L" Shaped Hallway - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 11:11 PM   #1
Installing 3/4 inch hardwood in "L" shaped hallway
Should I run the boards across the joists consistently as normally done; or should I do a 45 degree angle where the hall turns 90 degrees and use a transition strip to cover at the 45 degree cuts?. Both ways seem to have some appearance 'cons'.
MR. BILL'D is offline   Reply With Quote
Old 02-25-2012, 11:15 PM   #2
Rewards Points: 13,748
A whole lot easyer to do straight runs with no 45's.
You would not use a trasition strip, use splines instead so there is nothing sticking out above the floor.
Installing hardwood flooring tips?? pbthompson3168 Flooring 13 07-31-2011 08:22 AM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-17-2007 11:18 PM
Installing hardwood floors helpless handyman Carpentry 10 04-09-2007 09:23 PM
Installing Hardwood in Tricky SpotHi, georgemichael Flooring 1 11-20-2006 10:47 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
