Installed Stack Stone Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 08:42 PM   #1
Rewards Points: 55
Installed stack stone tile
Hi all,
Looking for advice. I know this may not be the right forum, but I am looking for advice about tiling and this is where most of the experts seem to hang.
I am looking to install stacked stone tile on my fireplace (vented gas/wood-burning), basically from the floor all the way to the ceiling, to create an accent wall (see http://www.norstoneusa.com/products/stacked-stone-cladding although i won't necessarily use this brand)
Could you provide some advice on what the proper prep process is for this? I am concerned that these tiles are heavier than the average tile. If it were a light tile, I could do it directly against the drywall, so what is the process for this heavier tile? Am I okay with just thinset (installation instructions seem to say so). The current wall is already finished, painted (latex) and textured, shuold I prep it in some way (sanding? dulling with water and TSP?)
The specs show about 12 lbs per sq foot for this tile. The walls are in good condition (~ 2005 construction).
Any other tips would be appreciated!
Installed stack stone tile-norstone-20charcoal-20rock-20panels-20dubai-20hub-27-20copy-1800.jpg
injvstice is offline   Reply With Quote
Tags
stone veneer , tille , walls
Duraceramic verses stone tile Ldieker Tiling, ceramics, marble 2 11-23-2010 05:05 AM
Anyone work with or put down Lamninate Tile or Stone planks? Sephora Flooring 3 11-11-2010 01:02 PM
Stone Fire Pit - free stack montgoss Landscaping & Lawn Care 2 11-08-2010 11:52 AM
Are cornerstones needed for faux dry stack stone fireplace? Lisa Highfield Building & Construction 0 06-09-2010 06:36 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
