Install Marble Flooring Or Cabinets First? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 10:29 AM   #1
Install Marble flooring or Cabinets first?
I am doing an extensive remodel on a high end home on the ocean. There are marble floors to be installed yet in the entire home except the bedrooms. The contractor went ahead and installed the cabinets before the flooring. I would think it would go the other way. Is there any logical way to know what goes first?
LA-FLA is offline   Reply With Quote
Old 07-29-2011, 10:39 PM   #2
The flooring is the last thing you should do...
ttr13r is offline   Reply With Quote
Old 07-29-2011, 11:10 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can install the floor first if you want to, there are no rules. You can install around the cabinets first and save a few bucks on the flooring. Installing the cabinets first eliminates any risk of damaging the floor during the cabinet installation.
Is your floor structure wood or concrete. If it is wood then that should be your utmost concern.
XXX
Need advice on what easy to install / inexpensive flooring options for bathroom floor amodoko Flooring 9 06-04-2011 04:23 PM
install kit base cabinets - floor not level eastside Carpentry 10 05-07-2011 10:09 PM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 04:55 PM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 12:35 PM
