Install In January- Buckel In August??? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2008, 10:41 AM   #1
I want to put down an engineered hardwood floor. I live in Atlanta and it is cold, heat is on, humidity in the house is 27%. I am worried that if I install now that the wood will expand in the summer and buckle. I am planning Thomasville engineered that will be stapled down to a plywood subfloor above a full basement. Will I have problems if I do it?
gas16 is offline   Reply With Quote
Old 01-05-2008, 08:47 PM   #2
The floor needs to acclimate to the house for a few days prior to install.
redline is offline   Reply With Quote
Old 01-06-2008, 12:06 AM   #3
Jaz
Of course the material should be brought into the room and all boxes opened and materials spread around to acclimate for a few days. But that is not his concern. He's worried that the humidity now is 27% and next summer it'll be 85% or higher at times.
My question is why is the humidity so low? You should be at 40-50% or so depending on the temp. Don't you have a humidifier on your furnace?
Jaz
Jaz is offline   Reply With Quote
Old 01-06-2008, 08:41 PM   #4
I agree with the concern on the low humidity. Our hardwood saleman for the Brazilian cheer hardwood we installed in the summer said that 35% was preferred for that type of wood.
However, I would be equally or more concerned about the 85% humidity in the summer. Are you not using a dehumidifier in the summer? 85% humidity in the house is not good, for more than just the hardwood, engineered or not.
Educator is offline   Reply With Quote
Old 01-06-2008, 10:00 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
He didn't say anything about 85%, I threw that in as a likely event, at least for a short period of time. A few cool rainy days and there you are. Even 60% is too high.
Jaz
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 09:05 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 01:27 PM
