-   -   Install In January- Buckel In August??? (http://www.diychatroom.com/f5/install-january-buckel-august-15204/)
gas16 01-05-2008 10:41 AM
I want to put down an engineered hardwood floor. I live in Atlanta and it is cold, heat is on, humidity in the house is 27%. I am worried that if I install now that the wood will expand in the summer and buckle. I am planning Thomasville engineered that will be stapled down to a plywood subfloor above a full basement. Will I have problems if I do it?
redline 01-05-2008 08:47 PM
The floor needs to acclimate to the house for a few days prior to install.
Jaz 01-06-2008 12:06 AM
Of course the material should be brought into the room and all boxes opened and materials spread around to acclimate for a few days. But that is not his concern. He's worried that the humidity now is 27% and next summer it'll be 85% or higher at times.
My question is why is the humidity so low? You should be at 40-50% or so depending on the temp. Don't you have a humidifier on your furnace?
Jaz
Educator 01-06-2008 08:41 PM
I agree with the concern on the low humidity. Our hardwood saleman for the Brazilian cheer hardwood we installed in the summer said that 35% was preferred for that type of wood.
However, I would be equally or more concerned about the 85% humidity in the summer. Are you not using a dehumidifier in the summer? 85% humidity in the house is not good, for more than just the hardwood, engineered or not.
JazMan 01-06-2008 10:00 PM
He didn't say anything about 85%, I threw that in as a likely event, at least for a short period of time. A few cool rainy days and there you are. Even 60% is too high.
Jaz
