Indoor Pool Room Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2014, 09:00 AM   #1
I recently built a sunroom onto my house that contains a swimspa. The room gets some moisture but not bad. I'd like to paint the floor but am unsure which product is best. The part of the floor that needs painted is not a super high traffic area but will get some snow on it during the winter from normal traffic. Please advise. Thank you.
Nancilla is offline   Reply With Quote
Old 02-25-2014, 09:41 AM   #2
Rewards Points: 13,472
What's on the floor now? If it's bare concrete tile would hold up much better then paint.
Old 02-25-2014, 09:48 AM   #3
Concrete
Yes, the floor is concrete right now. I'd rather not do tile. I'd like to paint it so I can do the work myself. I'm not skilled enough to do tile.
Old 02-25-2014, 09:52 AM   #4
Paints just going to wear off, tile should last a lifetime or more and is not all that hard to do.
Old 02-25-2014, 09:52 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 346
You should never paint a floor, indoor, outdoor, ever.
An area like that deserves tile.
If for some reason that's not possible, stain will do. It's much better than paint.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
wkearney99 (02-25-2014)
Old 02-25-2014, 10:00 AM   #6
Thanks JazMan
Old 02-28-2014, 10:25 PM   #7
Dave Sal's Avatar
Rewards Points: 634
You can do tile yourself. Just do some research and you'll come to realize that it's not all that difficult. Rent a wet saw for your cuts. It's basically spreading an adhesive (thinset) and then laying the tiles. Well, that's an oversimplification but laying tile is definitely a DIY project.
Dave Sal is online now   Reply With Quote
Old 03-15-2014, 03:34 AM   #8
James-Colls's Avatar
You can do ground yourself. Just do some research and you'll come to know that it's not all that complicated. Rental a wet saw for your decreases. It's usually increasing an difficult and then relaxing the flooring surfaces. Well, that's an oversimplification but relaxing ground is definitely a DIY project.
James-Colls is offline   Reply With Quote
Old 03-15-2014, 08:25 AM   #9
Dave Sal's Avatar
Rewards Points: 634
Hey, that's what I said.
Is that the Aussie version?
Tags
floor; pool; humidity
Mystery wet spots on living room floor littlecabbage Building & Construction 15 05-11-2012 10:13 PM
Remodel bonus room above gargage (need floor joist advance 22" span) Brianhoup Building & Construction 26 01-11-2012 10:40 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Anyone know if it is code for a utility room floor drain? tigerbalm2424 General DIY Discussions 3 10-17-2007 10:48 AM
