Old 02-03-2012, 10:31 AM   #1
Increase height of subflooring
I have been remodeling our master bedroom for two months and have run into some unfamiliar territory. I pulled the carpet in the bedroom and the subflooring is 3/4" TG OSB. The master meets up with marble tile in the bathroom and the hallway. The tile is 1" 1/8" higher than the subflooring. After the wife told me, "It will look terrible to have a step in the threshold" I am left with the problem of, how do I raise the subflooring height 1/4-3/8"?
Initially I was going to glue 1/4" cork down and then install the 5" solid maple planks over the cork. I started investigating on the internet and many people have had problems with this type of installation. So what I am leaning towards now is installing 3/8" ply over the subfloor.
My questions are all about installation methods… What is the preferred method?
-Glue and Screw?
-Run parallel or perpendicular to existing subfloor?
-Butt snug or leave gaps on joints?
-Screw Length?
-Should I be trying to hit the floor joists (I already screwed down the OSB with 2" subflooring screws)?
thiggins18 is offline   Reply With Quote
Old 02-03-2012, 05:56 PM   #2
3/8" ply is a good idea
-Glue and Screw? i prefer to staple anything less than 1/2"
-Run parallel or perpendicular to existing subfloor? it doesn't matter as long as you overlap joints at least 6"
-Butt snug or leave gaps on joints? butt is fine
-Screw Length? did i mention staples? 1-1/8" with 1/4" crown
-Should I be trying to hit the floor joists (I already screwed down the OSB with 2" subflooring screws)? not necessary
HarryJ is offline   Reply With Quote
The Following User Says Thank You to HarryJ For This Useful Post:
oh'mike (02-05-2012)
Old 02-03-2012, 07:24 PM   #3
Underlamnet is never glued to the subflooring.
Do not fasten the underlament to the floor joist. Your trying to pull the to together so there's no gap between the floor joist.
Old 02-05-2012, 12:43 AM   #4
Super Moderator
Harry and Joe have given you good advice---avoid hitting the floor joists--do not use glue---3/8 inch minimum thickness----screws are fine but slow and expensive---small crown staples (lots of them) are fast--easy and effective---
Old 02-05-2012, 07:38 AM   #5
Super Moderator
DO NOT GLUE---follow directions given by the pros--
This is an open public forum and not all advice is sound and backed by proper education and years of experience---
Old 02-05-2012, 09:38 AM   #6
Personally I would not worry about the 1/4" difference in height between the two floors. You will need a transition piece anyway as the two should have 1/2" between the surfaces.
framer52 is offline   Reply With Quote
Old 02-05-2012, 11:01 AM   #7
creeper's Avatar
Originally Posted by jasin View Post
"Glue it & screw it" (Mike Holmes)
Where's Bud?
creeper is offline   Reply With Quote
Old 02-06-2012, 09:13 PM   #8
Ok thanks. Just picked up the stuff to do it right now, 15/32 in. x 4 ft. x 8 ft. 3-Ply Rtd Sheathing is what I'm using... Thats ok right ?
Old 02-06-2012, 09:20 PM   #9
Nope, should have been underlament rated.
Sheathing will have unfilled knot holes in the plys, and not enough plys.
I also use a narrow 1-1/2 crown staple when attaching thinner plys. I can set it in automatic and nail a whole sheet in 1 min. and it leaves no dumples or big holes that would need filling it you were laying sheet goods.
Old 02-06-2012, 09:35 PM   #10
So I need the 15/32 In. x 4 Ft. x 8 Ft. BC Sanded Pine Plywood ? When I looked at it it looked like the only diffrence is the sanded pine vs the sheating was the sheeting was sanded... so what your saying is its sanded and filled?
Old 02-06-2012, 10:31 PM   #11
Tileguy
JazMan's Avatar
Sheathing is not for floors, as Joe said. it might be good enough since you're covering with wood, but............ The willingness to spend less can be costly in the end.
Absolutely wrong answer. The new underlayment must run parallel, but offset to the subfloor. In other words, all subfloor & underlayments should run perpendicular to the joists....always.
And of course no gluing to the subfloor and do not try to "hit" the joists. Of course if you use the right fasteners they will not be long enough to hit the joists. It's usually a good idea to leave an 1/8" gap between sheets and at least 1/4" at perimeter.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-07-2012, 09:49 AM   #12
Is the difference between the sanded ply and the sheeting ply the sanded is free of voids (and obviously sanded)?
Old 02-07-2012, 10:01 AM   #13
sanded only guaratees free of voids on the surface.
For your specific needs a cheaper standard ply will be great.
The extra benefits from a sanded product is just money flushed down the toilet.
Old 02-07-2012, 12:40 PM   #14
Arggggg Do I have to go to somewhere other than HD or Lowes? The only stuff they have around a 1/2 inch is 15/32 sheathing, 15/32 rated sheathing, and the sanded.
Old 02-07-2012, 02:43 PM   #15
What do you mean by standard plywood?
I've called around to building suppliers and my options are.
CDX yellow pine (sheathing), BCX plywood, ACX plywood, CDX Fire retardent, baltic birch (expensive), and sandply (also expensive).
I guess BCX is certified for use as underlayment.
Garage: Increase Wall Height c5er Building & Construction 3 03-16-2011 01:27 PM
Plywood to increase floor height? Kiwi. Flooring 3 01-17-2011 07:18 PM
Increase the height of base cabinets/countertop to 36" jstevens Remodeling 3 10-22-2009 08:47 AM
Increase counter height on bath remodel sharisavage Remodeling 4 01-22-2007 12:44 PM
