I'm Re-grouting...rotozip - Flooring - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 02:38 PM   #1
I'm re-grouting...rotozip
OK,
Instead of sending a million emails to our friend Bud Cline, I figure I will post a new thread and show some before and after pics of the project.
I decided to re-grout my kitchen floor. Hate the greyish color and the colorants just seem to be a non lasting choice. If I can re-grout the floor in a couple of days (300 sq. feet) with a friend, it is worth it IMO. There isnt too much grout either since I have 20x20 tiles.
A rotozip is probably what I will order and use it along with a utility knife. Thanks Bud for all your advice. Any other advice would be welcome.
THANKS
zman22 is offline   Reply With Quote
Old 05-16-2010, 03:16 PM   #2
the Musigician
DangerMouse's Avatar
I re-grouted one small bath that all I needed was a flathead screwdriver and a shop vac to dislodge and vacuum out the old grout! It was obviously a poorly done grout job as the tiles were all still quite secure. The new grout went in sweet and looked great though, I hope you have the same results.
DM
Old 05-16-2010, 04:10 PM   #3
Thanks for the info DangerMouse. I actually started a test piece today with a utility knife and a flathead screwdriver. The screwdriver worked pretty well after a few swipes with the utility knife. My tiles are solid so I dont see any downside to this. Maybe a lot of time is all. hehehehe
Old 05-16-2010, 04:29 PM   #4
the Musigician
Just follow the screwdriver with the vacuum and it goes pretty quickly. Po)
DM
Old 05-17-2010, 10:29 AM   #5
Hey DangerMouse,
What brand of grout did you use. I used TEC last time, but I am reading that Aqua Mix and Polyblend are good ones to use as well. Is TEC good?
Old 05-17-2010, 10:53 AM   #6
the Musigician
I used Poly....
DM
Old 05-18-2010, 02:51 PM   #7
Handyman
Rewards Points: 512
Be sure to buy a cheap screwdriver to do this cause after about 30 tiles, it aint a screwdriver any more,,,its a chisel!!
canadaclub is offline   Reply With Quote
Old 05-18-2010, 04:23 PM   #8
hahahaha
I'll probably buy at least 3 cheap screw drivers. The 20X20 tiles should help reduce the amount of grout to take out, but it's the (stronger) sanded grout. Hope this project doesnt turn out to be a nightmare. I'm 90% sure I am going to start digging. It should take one week if I work slow (with a friend) as a worse case scenario and well worth it IMO. I see no downside unless I start chipping tiles.
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 04:37 AM
Rotozip: How to Use for Electrical Boxes ralphfravel Building & Construction 11 07-24-2010 08:35 AM
Before I start grouting ... dahlias987 Tiling, ceramics, marble 5 01-03-2010 05:09 PM
Grouting Fireplace Tile Question roxksears Building & Construction 4 11-29-2009 07:21 PM
Grouting tile f.nando.campos Flooring 4 08-17-2008 09:54 PM
