Old 07-26-2011, 11:04 PM   #1
Post
Im installing 18 by 18 travertine tile for an hearth need some help
I am installing traverine tile that are 18 by 18 for a hearth thats gonna have a bio burning inset. (it burns wood pellets along with anything organic). So everything is being framed in metal then it has the cement board (has to be a non combustable material by code). So here I am with Travertine a tile Iv never used before. I know the thinset is put down then the tile, and it will have a very thin line in between with grout for totally sealing it. But one thing that bothers me is I have a about 2 inch trim piece around it. I know to install but does it have to have a space thats definet between the tile and the trim or what?? Not too sure if I can get a away with having a thin line there or not. Any help would be great!
kat10 is offline   Reply With Quote
Old 07-27-2011, 06:45 AM   #2
Super Moderator
A picture would clear this up-----typically the trim is applied after the tile---with the trim notched (rabbited) to cover the edge of the tile-----some space must be allowed for swelling and movement of the tile and wood----Mike---
Old 07-27-2011, 08:45 AM   #3
Tileguy
Bud Cline's Avatar
A "trim piece" made of WHAT?
What is the profile of this trim piece?
Tags
travertine tile hearth
Sealing Travertine Tile SatManager Tiling, ceramics, marble 17 02-23-2011 07:20 PM
Installing TILE on screen porch/concrete slab has a crack nasstee Flooring 2 02-22-2011 10:10 PM
Installing Hardwood Floor butting up to tile Macker Flooring 3 01-02-2011 04:21 PM
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 06:37 PM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 04:10 AM
